Huntindog wrote:
CAUTION!!!
Most if not all TT manufacturers expressly forbid the use of slide stabilizers.
The reason is simple. If the TT settles for any reason (soft ground under the TT jacks, or tires, or a tire with a slow leak etc.) the TT will lower, but the slides with their added supports will not be able to lower with the TT.
This will put tremendous pressure on the slides and the TT slide opening. SERIOUS EXPENSIVE damage is highly likely.
2x!!! Don't use them. Keep any and all stablizers under the main frame of the camper.
