kerrlakeRoo
Aug 23, 2018Explorer
colliehauler wrote:kerrlakeRoo wrote:Other then paying for it and filling in the hole left by the wall A/C.
Others are addressing the sink for you, but one other thought came to mind. The lack of AC that you mentioned should not necessarily stop you from a unit you otherwise like. If it has a standard vent opening in the roof, an AC can be added and likely the wiring is already in place.
If you used to work in this industry you should be able to either do it yourself or easily find someone to help.
The OP didn't say it had a wall AC. And the cost of the AC will either be there at purchase or later. The only difference in paying for it is if you want to finance the cost of the AC unit as part of the trailer.
44,030 PostsLatest Activity: Jan 21, 2025
