So I am a total idiot
a-d-s
No harm done, but I thought I would share by d'oh moment. On my hot water heater, I needed to replace the element so I removed the plastic shroud and the element. While I had that open I decided to give it a good flush. Of course a bunch of calcified bits come out and I hosed those away from the outside of the heater tray. Went inside and for some reason decided to have a look at the heater from the inside and saw a pool of water all around. Of course my first thought is that the tank is cracked and I am going to be replacing it. After I cleaned up the water (which didn't make it's way far) and searched online how much new tanks cost, I went back outside and looked at it from the outside and saw my mistake - with the plastic should removed from the heating element, I was spraying water directly inside the trailer!!! D'oh!
Anyway, no harm and now I don't have to replace my tank. Just feel stupid!
2021 F-150 HDPP EcoBoost
2016 Coleman 262BH
Reese Dual Cam - 1200lb
26 REPLIES 26
CavemanCharlie
I once flooded about half the trailer. Your moment is nothing. We all make mistakes. I wish I was as smart as you and have caught my mistake sooner.
brirene
That's pretty much my normal. :R You'll have to do better to achieve total idiocy to my level. 😉
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
toedtoes
I don't see that as a "d'oh" moment but rather a "YES!" moment. I'd far rather a potential water issue be due to my spraying water into the RV than anything else. 🙂
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
L2R
In my 20's, when I knew almost everything, I was proud to DIY and learn on my own.
Until I read the famous statement, "He who is self taught has a fool for his master".
That really hit home and a major reason why I read forums for information.
Just checked our bank account, we can retire today if I stop spending money now.
Lynnmor
Many trailers are not sealed between the water heater and the cover. When folks flush their tanks, the wall absorbs some water. It is best to caulk that area.
I drain my heater by opening the low point drains and the relief valve. This nearly empties the tank but it may not work with all trailers. Then I remove the anode or drain plug and quickly screw in a plastic nipple that is long enough to reach outside. I made a wand long enough to use with the nipple.
Helimech
It's good to learn from your mistakes, It's better to learn from others mistakes. Thanks for sharing
Dakota98
Really .........., & you thought you were alone in all this ?
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
RVcircus
If we didn't make mistakes we wouldn't have any good stories to tell. I have plenty of stories:S
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
BubbaChris
I did a similar doh-move yesterday while getting the anti-freeze out of my outdoor shower. I have a fan running inside today to circulate the air from that cabinet and where the water heater is.
2013 Heartland North Trail 22 FBS Caliber Edition
2013 Ford Expedition EL with Tow Package
chevyman2
a-d-s, if that is the "dumbest" thing you ever do, You will go down as (at least one of) the worlds smartest men. Dont feel bad buddy. As mentioned, we have all pulled a stunt like that before.
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 2001 Jayco KIWI
If a "nightmare" is considered a dream-then I am living the dream
Dog_Folks
Join the club, and welcome.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
scbwr
Anyone that does a lot of their own maintenance or DYS projects has at least one comparable story to tell. So, at least you didn't buy and install a new one before you figured it out!! Have a cold one and enjoy!
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
