So, Sorry for the same stupid topic again, but.. F350 vs 450
Boatycall
I've done a lot of thinkin lately, and a lot of readin. I'm considering a 2016 F450. For as much as they want for one, I'm not opposed to asking a stupid question.
Here's what perplexes me, and I need some input -
(all of this pertains to a DRW)
2016 F350 still has a Dana80, F450 has just come out with the Dana 110/111 - a 14k axle.
F350 has 17" tires, F450 now has 19.5's again.
F450 brakes/rotors are a full inch larger in diameter on front and rear.
F450 has over 40k GCVW
Why do both trucks have an identical 14k GVWR?
I've **heard** it's because of insurance, and if it's RATED over 14k it falls into commercial vehicle, but I can't verify.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
26 REPLIES 26
jimh406
Nautique200 wrote:
Wait a month until the new 2017 is released at the Texas State fair. I have heard of many new upgrades. 10-Speed Trans, Aluminum body and boxed frame. Just to name a few.
Who's 2017, Ford?
Nautique200
2016 Ford F450
2015 Arctic Fox 1150
2009 Trails West Warm Blood Trailer
Bedlam
Moderator
Moderator
There is a good chance that the F350 will have more payload available than the pickup F450. The F450 will have larger brakes and wheels with heavier axles and suspension than the F350. I don't know which frame they are now using in the F450 pickup - If it is the cab chassis frame, it is rated for more weight than the pickup frame. In recent previous years, it was the same frame under the pickup F450 as the F350.
DrtEMaxChvy
Chevy 3500 lol, here are my thoughts, the F450 is a capable and stout rig however the 350 will do all you want and then some.
450 comes in with the extra leaf in the rear and a reinforced front end (yes more so than the 350. Most will never use this feature to their potential.
2014 Silveraydo 2500 LML
: Fass 150 Lift Pump, Tuned, Firestone Airbags/incab controller, AFE intake, MBRP down pipe
2016 Jayco 29.5 BHDS 34'
languiduck
F450-F350 = 100. The difference between those trucks is exactly 100.
2006 F250
Palomino Bronco 800
Fastbrit
"So, Sorry for the same stupid topic again, but.. F350 vs 450"
:S
1997 Dodge Ram 3500 CTD. Timbrens all around, Bilstein shocks.
2014 Chalet TS116
_DJ_1
Bedlam wrote:
The F450 pickup has better towing capacity than the F350 but the payload is eaten up by the heavier running gear. The cab chassis version of the F450 has up to 16.5k lb GVW but expect 10k lbs plus for an empty fully outfitted truck.
This was the reason I jumped to the F550 and 5500 which have 19.5k lb GVWR yet don't weigh much more than the F450. I plan on a 6k lb TC, 500-1000 lbs of batteries, 500 lb front bumper with winch and close to 1000 lbs of tongue weight. I'm sure I could have scaled back to get within 16.5k lbs, but I wanted as many options available to me as possible in a compact chassis that still offered 4wd and crew seating.
This has also been my understanding. Tow heavy ~ F450. Haul heavy ~ F550.
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
Bedlam
Moderator
Moderator
Reality_Check
Nomad II
Nomad II
They're for different purposes...
Just as the p/u and the chassis versions are different.
The brakes are a HUGE difference...despite what people want to talk themselves into.
But for carrying, between the p/u versions (350/450) very little.
Just FYI...you can have a 'bed' put on a 450/550 chassis if it's carrying capacity you are shooting for.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
jimh406
I think F450s are about 500 lbs heavier and has different rear springs to haul a fiver better from all I've heard if it has a pickup bed. As you know, I'm also in WA, and my F450 is 14500 GVWR. The previous owner had a farm and registered it commercial. I had that changed since I don't use mine commercially. You can get a 16000 GVWR if you get one without a bed. I assume most of that is the spring pack.
I went with a F450 because they turn super tight, have better brakes, wanted the 19.5s, and I thought I might get a fiver in the future.
Kayteg1
I had 1999 F450 with Dana 80.
The door sticker was 15k, while I had it at over 20k quite few times.
Some interest when you load steam roller on pickup truck
Anyway, my F350 is having stronger suspension than older F450
Probably partly due new trucks build stronger, partly due that my truck was sold as extended wheelbase chassis.
Bottom line, even in the same year those trucks come with different suspensions, so good luck doing your homework.
Last time I check, diesel F350 were coming with $70K price tag?
Additionally, my observations is that till F450 trucks are build as grocery getter with short wheelbase, unless you get special order.
I had constant problem on F450 with weight distribution.
Short forklift at 10,000 lb was fine with counterweight behind the cabin, but 6000lb tractor would have center of gravity behind the axle and even air helper bags would not be enough for rear sag.
You want to get truck design for heavy weight, you need to go F550.
The_Mad_Norsky
I honestly think you'd be vastly disappointed in a 2016 F 450. I checked one out locally (more below) and I was indeed disappointed.
Yes, the 19.5 tires are a major plus, considering they should outlast anything we buy for the normal 17 inch tires we run on our current rigs (yours and mine both).
But Ford's got the F 450 made for pulling things with their 4:30 rear axle ratio.
It's NOT made for hauling a truck camper.
Local dealer has a 2016 on their lot, and I checked it out a few weeks back.
GVWR 2016 F 450: 14,000 lbs.
GVWR my Ram: 14,000 lbs.
Observations: comparing versus my current 2014 Ram 3500 dually:
Rear spring pack: I've got more on my Ram than the F 450 has. Very small spring pack on the F 450. If memory serves, at least one if not two springs less on the F 450 than I have on my Ram. I've got standard suspension on my Ram, no air bags assistance.
Rear axle weight rating: 9,000 lbs F 450. 9,750 my Ram.
Front axle: believe it said 5700 something. 6,000 lbs on my Ram.
Mind you, this F 450 had camper package AND snow plow package installed, and glove box DID recommend a truck camper.
But the weight given on that paper said max weight truck camper of 4,038 pounds.
Inside the driver's door, the max payload of the vehicle was given at 4,900 some odd pounds.
For my Ram, the glove box truck camper paper: 4,500 some odd pounds and total payload (driver's door) 5,380 pounds.
So, there's got to be a better choice than an F 450 out there. I haven't been able to find a new F 350 to check numbers on yet. But I suspect for TC hauling it is gonna beat an F 450.
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
