Jun-24-2023 02:44 PM
Jul-06-2023 09:19 AM
Jul-04-2023 04:29 PM
Boon Docker wrote:
Always thought that 13.6v was the typical charging voltage for LA batteries
Jul-03-2023 01:36 PM
Jul-03-2023 01:22 PM
Jul-03-2023 12:09 PM
Boon Docker wrote:ktmrfs wrote:canicon25 wrote:
I went and found the manual for the power converter/charger. It is an Elixir ELX-45. In the specifications section it says DC output is 13.5Volts 45Amps.
It also says "...designed to output a constant voltage of 13.5-13.6 volts at no load and 13.1 volts at full load to ensure trouble free service of all 12volt DC appliances."
Does this mean when plugged into shore with everything turned off the batteries would only be receiving 13.5-13.6VDC max? Kinda sounds that way to me.
yup, and your batteries will NEVER become fully charged and likely never get to the point where you see any bubbling. That also means since they never get fully charged, battery life will suffer.
Therefore it is likely that the solar controller is trying to get the batteries fully charged. hence the bubbling and noise. Assuming they are connected correctly to the solar controller.
Where did you get that information from?
Jul-03-2023 10:34 AM
Jul-03-2023 09:25 AM
Jul-03-2023 05:19 AM
Jul-02-2023 04:22 PM
canicon25 wrote:
Thanks all. Just wanted to bring this up again. I upgraded my charge controller to a Renogy Voyager 10A. The battery was only receiving 4A today (not very sunny out) and I heard the batteries bubbling again. When connected to shore power I don't hear the bubbling. Why is that? Just want to make sure everything is working as it should.
Thank you!
Jul-02-2023 03:39 PM
Jul-02-2023 12:40 PM
Bud
USAF Retired
Pace Arrow
Jul-02-2023 11:01 AM
Jun-25-2023 08:35 AM
Jun-25-2023 07:13 AM
