gbsb's avatar
gbsb
Solar Prep Help
I have a 2008 990 Arctic Fox. The previous owner had a ( one ) solar panel on the top. It is solar panel prepped. I found the plug on the roof to plug the panels into, the wires in the batter box to hook to batteries. I can not find the wiring that comes from the roof or tell where the wires from the battery box end. there is a sticker on the wall by the information panel that says solar hook up. Any idea where these wires end so I can connect to solar controller.
  • my 990 af is solar ready also, so I cut the hole and the wires were not there, had to stick my hand way up the wall and found the wires, they were there, lucky I have long, skinny arm, good luck
  • The wires were behind the wall with the sticker. I was just Leary of cutting a hole in the wall and the wires not being there. Panels on, controller installed, batteries wired, all that is left is to wire up the panels. tomorrow is another day.
  • I found my 1150 wires tucked behind the sink directly below that sticker....under the countertop obviously. Good luck!
  • The sticker on the wall marks the spot where you are suppose to install the solar control panel. The wires should be coiled up in the wall behind the sticker.
