camperdave wrote:
Qualityhouse wrote:
Yes, I'm pretty sure it was gray water as it was sudsy and smelled like soap. The water was coming out from the underneath of the left side of the trailer as one is facing the front of the trailer. It was the opposite side from the gray/black water drain. I was surprised because I didn't think the tank was that full, maybe 1/3-1/2. There was no water inside the trailer so it was coming from someplace underneath. I'll have it inspected when I take it out in the Spring. Keep the thoughts and ideas coming.
I sure wouldn't sit on this until next year! You need to find that leak, fix it, and see if anything else under there got wet
X2, X3, X4
Next spring you will be posting.."How do I get rid of mold/mildew, what kind of insulation is this and is it easy to replace rotted wood"
