johndeerefarmer wrote:
What do you store you spare water in? Plastic jugs? Plastic tank, barrel etc?
If you use a tank or barrel how do you get it out of there? Does it have an electric pump?
I see some using the 50 gallon tanks that you would spray pesticides out of. You can buy them at Tractor Supply but wondered how to get the water out unless you bought the one with a pump.
:E
Honestly? Pesticide tanks?
Even if you are not planning to drink the water from your RV fresh water tank do not use ANY vessel, tank, jug, barrel which is NOT rated as "potable", "food grade", "food safe" or safe for human consumption..
Even if those means are brand new, many of these tanks are not made from plastics which will be safe for human consumption. Those plastics often contain chemicals which can leach out into the water over time..
So to recap.. You WANT to buy and USE containers which are specifically labeled as "potable" or safe for human consumption.
Pesticide tanks do not meet this criteria.
Even if you don't plan to drink from your trailer water system, the NEXT OWNER just might and the chemicals that leach out could potentially harm the next owner and or family..
As long as the tank is new, has been cleaned and isn't made from BPA or other hazardous chemicals a 50 gallon "pesticide" tank is not a pesticide tank until you put pesticides in it.
Read the text in red on this page in an ad for a pco (pest control operator) tank
pco tanks
Unless the tank SPECIFICALLY LISTS FOOD GRADE or for POTABLE WATER USAGE it IS NOT designed or sold for the use with human consumption..
Using your logic folks might even consider using off the shelf gasoline cans for their water.. Don't you see the potential of incorrect usage?
Food grade containers are designed and guaranteed by the manufacturer for that specific use. Using containers designed for other usage is inviting potential cross contamination..
Food grade containers ARE NOT HARD TO FIND and not any more expensive than using a agricultural pesticide tank. Food grade containers are also FDA approved which NONE of the tanks uses have this approval.
HERE is an example of FOOD GRADE containersMany containers also have color designations to boot.. Gas cans are red, diesel and kerosene is yellow. The colors are supposed to help in preventing using the wrong "product".. Mixing up the usage can result in disaster down the road. Just because YOU "know" what you were using it doesn't mean someone else will "know"..
A fool and his "life" are soon "departed" when they fail to heed the warnings..
