Your truck should have a knock sensor...it is NOT working for some reason and
should have set a code(s)
Bumping up the octane is only a poor band aid for something that *WILL* destroy
your engine
*IF* that is an ignition knock...it could be something else altogether
I've had folks tell me it is ignition knock that turned out to be a rod going bad
Have it checked out ASAP and get the code....again, in today's ICE's...they
have knock sensors to either retard or go into limp mode.
Knock sensors are cheap and hope that is all it is
DO NOT DRIVE IT FAR while it is this way
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
