โNov-21-2014 08:53 PM
โNov-24-2014 04:08 AM
โNov-23-2014 05:57 AM
Tankcar wrote:
Hi. Why are so interested in fuel mileage? You are towing another vehicle thats (dead weight). The higher you go less mileage you get.
โNov-23-2014 05:51 AM
transamz9 wrote:Lantley wrote:transamz9 wrote:Lantley wrote:
The difference in MPG is negligible 1 MPG at most.
Whatever the dually lacks in MPG's is returned via additional braking power.
DRW vs. SRW MPG's is really a non issue.
I still don't understand the braking thing. The brakes are the same on the SWR as the DRW trucks unless a model change. I have never ever been able to lock up my rear wheels on my srw trucks while towing.
The DRW simply gives you more tire surface on the ground which translates into more braking surface,(twice as much surface).
In the end the additional tires provide better braking.
It's not a matter of locking up the tires but a matter of a shorter stopping distance.
Imagine if Fred Flinstone could have stopped using 4 feet vs. 2!
My point is that the brake pads, rotors and hydraulic system does not have enough power to make two wheels slide with a load on it so how is two more wheels going to make you stop faster? If anything, the two extra wheels and fenders is more weight to stop. :S
โNov-23-2014 03:24 AM
jerem0621 wrote:
I had a 99 V10 3.73, Dually LB CC 2wd...I got about 9.5 empty and 7.5 towing.
How much is the dually MPG penalty? I mean, if my truck wasn't a dually, what would my MPG have been? Would it have been 10.5 empty or more?
Reason I am asking is because we are talking about getting back into RV'ing and I need a truck that can do double duty as a DD at 60 - 70 miles per day. The previous LB Dually had problems in my works parking garage so there is a strong likelyhood that I will have to go with a SRW Shortbed truck.
Thanks!
Jeremiah
โNov-22-2014 03:26 PM
โNov-22-2014 03:13 PM
โNov-22-2014 08:09 AM
โNov-22-2014 07:30 AM
โNov-22-2014 06:12 AM
Porsche or Country Coach!
โNov-22-2014 06:10 AM
lenr wrote:
6 wheels on the ground compared to 4 wheels on the ground is not twice as much braking surfaceโ1.5 times as much. Extra weight from heavier dually suspension reduces mileage. In Fords a dually always comes with higher numeric rear ratio making engine spin faster causing lower mileage. GM had a white paper out a few years ago saying diesels are more susceptible to reduced mileage from high engine RPMs than are gas engines. Luckily the low RPM torque peak in diesels lets you gear them for slow RPMs if you got a big enough engine. My son went from 7.3 regular cab long bed 16 mpg to 7.3 crew cab long bed dually 12 mpg. Your results may vary.
โNov-22-2014 05:37 AM
โNov-22-2014 05:28 AM
โNov-22-2014 05:22 AM
โNov-22-2014 05:15 AM
