Tireman9's avatar
Tireman9
ST225/75D15 Recall
NHTSA Campaign ID Number : 14T001
Synopsis : Double Camel, in cooperation with Lionshead Specialty Tire & Wheel LLC (Lionshead), notified the agency on January 21, 2014 that they are recalling 1,440 Vail Sport ST LH 99 tubeless trailer tires, size 225/75D15, load range D, DOT code 69, manufactured from July 14, 2013, through July 27, 2013 (and a sidewall date code 2813 or 2913). On May 7, 2014, Double Camel increased the recall to include an additional 38,129 Vail Sport ST LH 99 tires encompassing build dates from November 20, 2011, through September 21, 2013 (dates codes 4711 through 3713). The total population of the tires being recalled is now 39,569. The original population of tires may fail under prolonged use and may become unseated from the rims and the additional population of tires may be more susceptible to failure due to road hazards. As such, these tires fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 119, "New Pneumatic Tires for Vehicles Other Than Passenger Cars." Tire damage from road hazards, failure from prolonged use or unseating of the tire from the rim increases the risk of a crash. Lionshead will notify owners, and dealers will replace the tires with compliant ones. The recall of the initial population of tires began in February 2014. The recall for the expanded population of tires is expected to begin in June 2014. Customers may contact Lionshead at 1-574-533-6169.
  • Another recall 14T003
    Synopsis : Double Camel, in cooperation with Lionshead Specialty Tire & Wheel LLC (Lionshead), is recalling certain Vail Sport ST LH 99 tubeless trailer tires, size 225/75D15, manufactured from April 2012 through February 2013. The affected tires may not be marked with the load range letter designation. As such, these tires fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 119, "New Pneumatic Tires for Vehicles Other Than Passenger Cars." Tires that are missing the load range designation may cause the owner to unknowingly overload the tires, resulting in a blow out, increasing the risk of a crash. Lionshead will notify owners, and dealers will replace the tires, free of charge. The recall is expected to begin in June 2014. Owners may contact Lionshead at 1-574-533-6169
  • Another option is to make sure your tires are registered bu either the RV dealer or tire dealer.
    While there are some dealers that don't want to be bothered I believe that some do not realize they are suppose to either register the tires for the customer or provide the forms for the customer to mail in.
    Either way I strongly suggest that everyone have the full DOT serial, including the date, somewhere in their documentation. You only need to record the numbers one time.
    I am trying to confirm if it is possible for individuals to obtain the form and file it themselves even if the dealer failed to provide the form at the time of sale.
    If this is possible I will do a post in my Blog on this topic with the details.
  • Thanks for the information Tireman…
    We should all check the recalls for our particular vehicles at least every 6 months… as important as it might be it really seldom seems to draw much attention to the general population…
    A good and easy starting point, but there are other reliable sources to…
    http://www.arfc.org/rvs/
