thealexdexter's avatar
May 09, 2016
stable load clearance on 2015 sierra 3500HD
I'm thinking to add stable loads to the upper overload spring on 2015 Sierra 3500HD, just to level when loaded with TC. In researching ride unloaded it seems maybe there is an issue with GM vehicles not having enough upper clearance to the spring which hurts unloaded ride quality. I know lower stableloads are not available due to clearance issues, so the quick adjust version is not an option.
How much clearance is there from the stable load to the upper spring when unloaded?
Can the stable load be trimmed to make a bit of clearance? It looks like it might be possible.
Thanks.
  • My upper SL were in constant contact w/ aux springs which makes for very harsh unloaded ride as you mentioned. Called TL and they said it was okay to cut/trim as needed but gave an initial suggestion of 1/2". So I used a jigsaw with them still in place and fair success. Bought a 4 1/2" grinder which worked better, but more messy job. Still may have to cut more off the rears as they are touching w/ full fuel tank. Wasn't when I did it, but truck wasn't level either. I have about 1/4" to 1/2" w/ the fronts and try to have the same for the rears.
    Word of caution if you use cut off/grinder with them on truck: wear leather gloves, long sleeve shirt you don't care about and safety glasses. The melted rubber got all over the grinder and now have to figure out what to use to remove it from it.
