Camper_Jeff___K
Feb 05, 2019Navigator
Static Shock!
I was sitting in the camper doing paperwork and noticed the battery voltage getting low from running the inverter. I reached up to the solar charge controller to press the button to show amps charging and a large static discharge occurred. It seems to have fried the voltage display readout. The amperage readout still works however. I can always get my DVM to check voltage in a pinch or get a secondary display unit to show a readout all the time. Or I can bend over and get a new charge controller. I was going to wait on that until I get another 170 watt solar panel and install an MPPT controller. I still have to determine if the unit is still even working, charging the batteries. I'll keep you posted. Perhaps people should wear static bracelets while in the TC.
