Johno02 wrote:
If you are going that far each day, your aren't RVing, you are just driving! Stop and enjoy the flowers!
Unlike posts like Dutchman's how does this help the OP get in/out of gas stations? When doing the 1500 miles to Colorado I do it in two days because there is nothing in between I need to see again... what business is it of yours how many miles I drive or why?
X2 on using GasBuddy, especially for saving $0.15+/gallon on fuel by going a couple of blocks further from the interstate. I have not used a truck stopped since Pilot bought FlyJ and their prices have gone through the roof compared to stations close by.
I'm as long as you are and I almost always have to use the in the end pumps were the diesel is located. With the DW watching you should be able to back out of a tight situation... less likely to happen if you use the end pumps. Backing up with the DW helping is something you need to get good at... before going to the campground, although it does make for good entertainment for the other campers.
With a little experience and practice you will wonder why you ever worried about this.
