nrm_camping's avatar
nrm_camping
stove issue
i own a 2016 palomino puma 32dbks. pilot light on stove will light and burner on stove will light with no problem. Issue is that pilot will go out after 5 or 10 minutes.Tried relighting several times but continues to fail.has done this right from new. Any ideas before I haul it in for service? hope it is a simple fix.Thanx
  • I second the thermocouple idea. They are cheap, replace it.
  • ok I will check this. Should mention that today it was acting its bad way,wife was using cook top burner, I lit pilot and it didnt go out the whole time she was using the cook top. Turned cook top burner off and the pilot went out seconds later. Very odd.
  • Check the thermalcouple. It needs to be directly in the pilot flame.
