Sunlite Camper Dump Valve
niftypkg
FYI the 3" dump valve is labeled Dorset. It is located at the rear on the right side. Works OK. It is the plate against the camper siding that is UGLY and cracked. I suppose it is just a closure plate. I want to replace it. Looks like I would need to take off the Dump Valve? Is that what it is? Any Sunlite owners out there?
1 REPLY 1
SidecarFlip
'Nobody' on Truck Camper forums www.truckcamperforum.com has one. You might try there. He's usually around. I'm sure he can answer your questions.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
