WanderWest
May 28, 2016Explorer
Suspension Advice - F350, Truck Camper and Fifth-wheel
I have a 2014 F350 dually that has been towing a fifth-wheel with about a 4,000 lb pin weight. Stock suspension, with the fifth-wheel hitch mounted in Ford’s bed mounting holes. The truck has the max stock springs front/rear as well as the stock stabilizer bars front/rear.
A recent weigh showed 300 lbs less on the front axles with the trailer hitched (not ideal), although I’ve towed about 13,000 miles so far and it didn’t seem to affect handling. Still, transferring some weight back onto the front axle would be good.
I’m also picking up a truck camper in two weeks to use for trips where we want to be smaller and more mobile. The truck camper will weigh in at 5,000+ lbs (depending on how much water is loaded), and I am assuming that we’ll want to do something with the suspension given that heavy of a load.
Internet and forum searches have turned up a wide range of approaches: air bags, Timbrens, shock upgrades, spring upgrades, Supersprings, StableLoads, etc. Given my two different loads (fifth-wheel and TC), I assume Timbrens would not be a good choice (for me). They recommend their regular system for the fifth-wheel and the severe service version for the TC.
Otherwise, I’m not sure about the best place to start. I have no practical experience with tweaking/upgrading suspensions for heavy loads, and in this case I need a solution that will work unloaded, with a ~4,000 lb load that is currently unweighting the front end slightly, and with a ~5,000+ lb load.
Thanks in advance for your help.
--WW
--WW
