S&B123 wrote:
Me Again wrote:
S&B123 wrote:
Just an update.
After a lot more research trying to get info on the subject of payload and towing capacity, according to GM as of 2014 all payload stickers on the doors of their trucks include ALL occupants, 5 in my case with all full fluids including full tank of fuel. The posted 2910# on my truck is actual payload capacity "after" these items were factored in. Apparently prior to 2014 GM weighed their vehicles without full fluids and added options.
That being said we are looking at 5ers a bit less in the GVWR than the two I mentioned.
Thanks to everyone for your input on the subject.
I do not believe that is true about all occupants. It is a 150 pound driver only. The change they made was to use the actual trim level of the truck vs a stripper. Chris
Chris, I called GM and verified that on my 2016 truck the calculation includes all passengers (5) at 150lbs each.
Whether I'd take that as true or not depends on "who" at GM you spoke to.  Unless it was a GM engineer IMO the answer is potentially suspect.
Anywhoser, regardless what GM or anybody here on rv.net says, if you really want to determine the realworld payload for
your truck I'd suggest weighing your truck empty, with you on-board along with a full tank of fuel, at a nearby CAT scale.  Subtract this weight from your truck's GVWR.  The resultant number is your realworld remaining payload---more accurate and applicable than the yellow payload sticker on the door jam.
The yellow door jam payload sticker only reflects the remaining payload the day the truck left the assembly line, prior to being subjected to dirt, mud, rust, hitches, different tires/rims, over/underweight drivers/passengers, and modifications---known and unknown.
