Me Again wrote:
S&B123 wrote:
Old-Biscuit wrote:
GO out to your truck
Open drivers door and look on door jam
Tire Data Sticker----Yellow with have cargo carrying capacity
PAYLOAD.
Also note the info.........All Occupants and cargo must not exceed XXXX lbs.
PAYLOAD.
Both of the 5vrs you are interested in have DRY pin weight of 2000# which means when they are loaded up camp ready the pin weight will be closer to 2800#
How much PAYLOAD is listed on that Yellow Sticker????
Got enough for that amount of WET pin weight after subtracting the weight of ALL occupants/cargo (stuff inside cab/hitch in bed)???
Thanks very much!!! Shows 2910#. Was able to find out that includes one 150lb driver and all fluids to full per GM.
Another number to look at closely is the rear GAWR.
Actual rear axle weight, plus hitch and things in the bed, plus pin weight needs to equal an amount less the rear GAWR.
Chris
And then look at trucks rear tire MAX Load Ratings at MAX PSI.
SO rear tires, rear axle and payload numbers
OP....
2910# Payload per door sticker
2800# Wet Pin weight of either of those 5th wheels you are contemplating (I tow 14K 5vr---actual pin wet is 3000#)
That only leaves 110# for occupants/stuff
RAWR...6200#
GVWR....9500# ???
Quickly running out of truck.....so need lighter trailer.
Check into ones that have a GVWR of 12K or less for happy towing.
Happy towing results in more towing which means more fun cause you go more often
(VS...I hate towing this)
