Yngrver's avatar
Yngrver
Tank Problems
The dreaded "tank problem"s....
I am having trouble with both my gray tank and my black tank.
1) My gray tank is continuously clogged. I have to take a plunger to it about once a month to empty it. I have to plunge both inside the tub and on the outside where the valve is. When the water comes out there is a big gush and these white things come out with the water. The debris looks like big white pieces of deodorant though it is not deodorant (just looks like it). I am guessing it is big pieces of grease.
2) This morning when I went to flush the toilet I noticed that it appeared to be clogged/full. I went outside and opened the valve to empty it. There was a nice flow into the sewer line for about 5 seconds and then a slow trickling sound of water. I went back inside to the bathroom and flushed the toilet and the toilet was still full. The solids had not moved but it appeared that the liquids had not moved either because as I was flushing I could see the solids moving and floating around. I did not leave the valve open anytime so I am assuming that there is not pyramiding going on.
Any suggestions or ideas for both of these issues? Do I need to have someone come suck all this "crap" out? I saw where some people mention different chemicals I can buy. Thanks for the help.
