towpro
Feb 18, 2015Explorer
TC off the grid, and solar question
when we get the new camper, we might try doing 2-5 nights without electric this fall out at the beach.
Sure I will have a generator but I only want to use it if AC is needed.
So looking at what many on this forum have printed about there system, but this brings up a question. The solar charge co9ntrollers are a little different.
Some have Load terminals
Some have 2 battery outputs.
Does the 2 battery outputs treat each battery different? or is it just a convention way to wire 2 batteries.
The ones with Load terminals: If its a 30A controller, I assume that means don't put more than 30A solar charge load through it, but does it also mean the load side is only good for 30A? (I understand you don't wire the on-board AC/DC charger through this).
TC content:
How much current does a TC run for just day to day living (no AC inverter for microwave).
Refreg on propane, hot water on propane, couple LED lights, maybe heater starts, will the load ever go over 30A?
The only High current stuff I might run is a small inverter to run a Satellite receiver.
TC content:
