โJun-21-2019 09:07 AM
โJun-23-2019 05:04 AM
myredracer wrote:
Not sure if I can get it above the coroplast.
โJun-22-2019 07:04 PM
drsteve wrote:Picked up some #12 SAE brake wire today. I'd have to special order #10 and need it now and #12 should be fine for the length involved anyway. Definitely will be better than #18! There's a propane pipe under the I-beam I'm going to zip-tie it to. Not sure if I can get it above the coroplast.myredracer wrote:Ductape wrote:And I have to question their use of #18 wire. I'd like to upgrade that but wouldn't be an easy job as it's hidden behind the underbelly.
Can't do better than a low resistance soldered connection. I've done the same on brand new trailers.
On my Coachmen, I plan on running #10 to each wheel, so I removed a few screws along the edge of the underbelly to take a look, and the brake wire is just laying on the coroplast. Should be easy to run the new wire.
โJun-22-2019 05:54 PM
โJun-22-2019 12:31 PM
Gdetrailer wrote:
First of all, in the RV industry, the workers are not paid "by the piece" so you cannot call it "piece work".
RV production floor workers are most likely paid an hourly wage.
Point number 1, you can get the "I don't care" attitude even with salaried or hourly, doesn't matter.
Sometimes the problem is the worker doing the work (not trained or not caring), sometimes the problem is bad management or high pressure from bad management to push stuff out the door before it is ready. Sometimes it is completely bad Engineering and Management turns a blind eye to it.
Most RV manufacturers use moving production lines with specific work cells which do specific assembly at certain times in the assembly process.
Workers are often hurried to complete their part of the assy process before the entire unit is pushed past their work cell. Often with zero "QC" involvement in this final process of integration.
Point number 2, I guess you have never worked in any assembly plant or have setup a production floor. Depending on complexity of your device, having EACH assembled part in each section "inspected" by QC at each step of the way may or may not make sense..Workers may be fully trained in one work cell or all, partially trained or even no training other than watching someone show them once. I seriously doubt that there is any dedicated electricians, carpenters or any other specialized trades on the production line, it would cost several arms and legs to do so.
A RV, nope, not worth the extra cost in man power, the worst you have there is a slight delay in your plans.
Not to mention absolutely no one would be willing to pay double of what a current RV costs..
Point number 4, dealers wouldn't exist since RV manufacturers wouldn't exist since the prices of the RVs would be far more than what folks could afford to buy and due to zero sales putting a lot of workers out of a job from the workers making the materials that the RV manufacturers buy, the production workers building the RVs right through the RV dealers..
The use of the mass production line speeds up the building process, lowering the cost to make which lowers the final cost to the end user.
Mass production is not perfect, but often the mistakes made are much lower than say a "one off" that is hand built by just one skilled laborer..
Take your pick, have RVs of may many styles and floor plans built in a quick time and much lower cost (mass production) or one plan which takes months or even yrs to build at a cost well above your income level (hand built one off)..
The cheap wiring like the OP has is often a manufacturers cost cutting decision to find ways to use leftover scraps
โJun-22-2019 10:18 AM
dodge guy wrote:I've heard of some experienced mechanics making really high incomes because they can do the work way faster than the book rates and they split the difference with the shop owner(s) over what they charge a customer.
Thatโs exactly it. Iโm an auto tech and we work by booked hour. I take my time to make sure itโs done right. Take a extra minute and it doesnโt come back where you need to spend 30 minutes. And you have a happy customer.
โJun-22-2019 08:44 AM
JRscooby wrote:Old-Biscuit wrote:
PIECE WORK......DOES NOT PROMOTE QUALITY WORK
NEVER has....NEVER will
#1 Not sure that is the problem. Hourly pay, you can still get the "I don't give a snot" guy plus you get a large percentage that instead of looking at what might be a better way "So what? The're paying me head down." And if CQ catches a defect, the company pays for the hours to fix it.
#2 IMHO, the problem is lack of inspection as it is built. The workers are paid for each job finished. If it was inspected, and found wrong, the worker does not get paid to do that job, or has to come back and fix it for free. Because each worker is wanting to make as much as he can he is always looking for a better way. And for the same reason he will be sure the product meets standards.
#3 I thing the problem is people keep buying the trash, there is no reason to hire the inspectors. WE lay the money down, try to use it, take it back to the dealer. Then for the next period of time, days weeks or months the dealer has our trailer and part of the money, the manufacturer has rest of the money, you got squat.
#4 Look at numbers; at any given time a busy dealer might have what 3 potential buyers on the lot? And at the same time, at least a dozen RVs waiting for warranty work? What would happen if say a third of the people that payed for squat stopped by[/] the dealer to check on the RV they don't have, then stepped into the sales area to report their "Joy of ownership?" At the very least it would get the sales force whipping service dept. And it would not take long before the dealers to realize "I can't really sell if I have all this warranty work," and he would refuse to accept the bad RVs.
โJun-22-2019 08:16 AM
โJun-22-2019 04:38 AM
โJun-22-2019 04:26 AM
โJun-21-2019 05:36 PM
BillyBob Jim wrote:Yup! Being the EE and the "can't leave it alone" person I am, there isn't much electrical I haven't touched, repaired or modified.
Myred, have you ever pulled the cover and nosed around the inside of the 120 side of the converter box? How about pulling the sidewall mounted shore power connector if you have one and look at the connections, or poke around in the junction box at the connection if you have a power cord in a mousehole?
You may find lots of interesting things if you do so.
The RV Industry - What me worry?
โJun-21-2019 01:47 PM
โJun-21-2019 01:34 PM
Lynnmor wrote:Lol! Yeah, and our Spree is a few years newer than yours. It definitely looks like they made big advances in quality control in that time... :M
Hey, myredracer, quit complaining, you got one of the better ones. :W
โJun-21-2019 01:11 PM
Gdetrailer wrote:
Reducing the resistance a lot will vastly improve your braking enough that you can turn down your controller.
While you are at it, abandon the wiring that is going THROUGH THE AXLES! Wire tie to the outside of the tubes or attach to the underside of the trailer then drop at the ends of the axles. That is another point of intermittent brake issues when the wire chafes or breaks inside the tube..
If you are going to work on your brakes, do it right the first time, then you won't have to do it again down the road..
โJun-21-2019 12:59 PM
