aarond76
Apr 09, 2013Explorer
Testing Trailer Brakes with Break Away Cable
Trailer has weak brakes even with controller set to full power.
Two trips back to dealer and dealer states brakes work fine and problem is with my vehicle (wiring). I do not believe them. The controller stopped my other trailer just fine set at much less than full power and would easily lock the wheels.
Can I pull the breakaway cable on the trailer to test the brakes. After pulling the cable in a parking lot and pulling forward it should lock the brakes up correct? If it locks the brakes with the breakaway cable pulled then the problem is on the van side. If it does not lock the brakes up then the problem is on the camper side.
How do I reset the breakaway cable after pulling it out? How long can the breakaway cable be pulled out before you start to cause problems fully energizing the brakes for a long period of time? Obviously I am not planning on driving down the road with the break away cable pulled.
Thanks.
Thanks.
