- donn0128Explorer IINO! 24-Volt means it requires double the available power your trailer has.
Better choice is a Hunter Douglas battery powered thermostat available for about 25 dollars at Walmart. Add a 4 dollar SPST switch from Radio Shack and you will also have two speed fan for your AC. - downtheroadExplorerdonn0128 is correct...needs to be battery powered.
This is the one I used...works great. I did add a hi/lo fan switch.
Honeywell TH3110D1008 Pro>>> LINK - samhain7ExplorerThe one I provided a link to does have two AA batteries...
The issue I have is that they do not sell the HUNTER brand in Canada. So I am (and probably others in Canada) looking for GOOD alternatives..
I have seen about two comments in this forum that Honeywell is not recommended.. - kaydeejayExplorerHmmmmmm "This thermostat could be used on single stage furnaces and air conditioners including 24-Volt."
does NOT say it can only be used on 24V systems.
I would contact the Manufacturer.
FWIW MOST electronic thermostats have a couple of AA batteries to keep the clock going. - downtheroadExplorerI took a look at my spec. sheet....re: the unit I referenced above. Mine says: Specifications: Electrical Rating: - 24 VAC (18 to 30 VAC). It works just fine so maybe the one you are considering will be good also.
(see my post and link above) - samhain7ExplorerHey downtheroad .
We don't even have the one you listed in Canada.
Lots of Honeywells...but not that one..
:( - 2oldmanExplorer IIYou don't have to buy a Hunter. Any battery operated digital, including that one, is fine. The other posters aren't reading carefully.
I have a Lux w/remote and it's real nice. - SoundGuyExplorer
That "24 volt" reference is to typical home heating situations which are commonly 24 volt ac and has absolutely nothing to do with your trailer's 12 volt dc system. Good grief! :S
Since you're here in Canada as I am where many products common to US consumers aren't available the solution is simple ... just head to your local Home Depot and spend $50 on this Honeywell Non-Programmable Thermostat that will work perfectly for controlling the furnace and/or air conditioner in your camper and which is particularly easy to use as it features a backlit display that lights up whenever you push the temp control buttons. - samhain7ExplorerThanks SoundGuy. Exactly what I was looking for...
- Dakota98Explorer
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 13, 2025
