Sort By
colliehauler wrote:
When you switch from Diesel to gas vechicle do you find yourself waiting for the glow plugs/ grid heater to warm up?
Yes, I do it all the time, which is odd considering I rarely drive my diesel truck... so it should have developed as a regular habit (since the truck is not my daily driver).
my Jeep is my DD, and about half the time I get in it, I turn the key and wait.- APTExplorerMy diesel starts within 2 seconds over freezing. I have started it as cold as zero degrees F while waiting an additional second.
- christopherglenExplorerI usually remote start everything, then the alarm does the waiting, not me. I prefer to turn keys to run, wait a second or two, then crank them. That gives gas (injected) fuel pumps time to build pressure before attempting to inject, and diesels to cycle the grid heater / glow plugs.
- TystevensExplorerYep, I developed a hitch in my ignition key turning (turn 2 clicks, wait a second, then turn the starter) that took about 3 months to go away after I sold the diesel.
- Slated4GreatnesExplorerNot only do I wait to start I look to where the EGT gauge is to make sure it is cooled down before shutting off... Old habits die hard..
- GoPackGoExplorerI don't understand some of the comments from folks who have the Ford 6.7 and state that it's instant start, there are no glowplugs and no wait time.
I don't believe that's accurate.
My brand spanking new F350 6.7 has glow plugs and a 'wait to start' light. The light only comes on for a few seconds here in Florida (usually only the first time it's started in the morning), but it does come on. And I know it's easiest on the engine to let the glowplugs do their thing before cranking the motor. - Ram4SamExplorerI don't have that problem......My problem is when driving my Honda, I keep stomping the floorboard when trying to push the clutch pedal that isn't there.......:S
Sam - mtofell1Explorer
tanman32225 wrote:
no.. my diesel fires right up. never had to wait on glow plugs
Just because it "will" fire up doesn't mean you should turn the key :)
I see you live in Florida so it's probably not a huge deal but in colder climates it's hard on things if you just crank it right over. - Perrysburg_DodgExplorerHonestly any fuel injected vehical you should wait a few seconds to allow the injectors to fire, right?
Don - BigToeExplorerI wait to start in all of my vehicles:
- in the Diesel truck, because of the Wait to Start light.
- in the Gasoline Hybrid car, because I can't figure out HOW to start it.
- in the Gas truck... because I'm AFRAID to start it (due to the noise it makes).
So yes in answer to your question. I wait to start.
All vehicles. All fuels. Always.
I'd make a terrible fireman. I can never leave in a hurry.
About Travel Trailer Group
44,029 PostsLatest Activity: Apr 26, 2025
