MLD's avatar
MLD
Thoughts on Lance Nose Cap Filon Replacement
The nose cap filon on my 2006 Lance 951 started delaminating a year or two ago, some of it may have been due to bad caulking on a marker light but some is separate from it and I think it's just a result of old glue and heat from sitting in the sun for 17 years, but it has progressively gotten worse and is very unsightly. I've removed some of the trim to inspect it and while the sidewalls are laminated to plywood the nose has a hardboard/fiberboard backing that is less than an 1/8" thick and appears to be curfed on the back in the areas where it bends around the curves of the nose. I would need to remove both the filon and backing to do the job right, I can buy some filon and 3M 1357 and have plenty of experience laminating but have no idea where to get such a backing. The rest of the camper is in perfect condition, other than the faded & cracked decals, so I would like to keep using it and fix the nose, so I'm looking for thoughts on how to fix it with filon or maybe something other material. I wished it was as simple as replacing the old aluminum siding. Thanks for any ideas.
