epcolumbus
Mar 04, 2020Explorer
Tie downs
I am new to truck campers. Looking at used ones. Can I safely mount a 1000 lb camper on my Ram 1500 short bed using heavy duty ratchet straps and the factory tie downs in the bed. Looking for opinions.
Specta wrote:
And he mentioned the camper only weighs 1000 pounds. That's nothing for good straps.
jaycocreek wrote:
Sorry for some of the rude and uninformed replies..Some just have no idea and have never done anything like that..Some have..
As far as using straps,I am totally surprised someone hasn't came up with truck camper ratchet tie downs..There are recovery straps out there rated over 30,000 lbs and ratchet straps rated at 20,000 pounds and only 2" wide...Working loads over 5K on the little ones.More than enough for a truck camper like you asked about..
They give alittle unlike turnbuckles and chains,a good thing for a TC..And some of the colors are awesome..LOL..That's all the truckers use to tie down there very heavy loads of lumber etc..Been there done that..
Good luck with your new rig...
You are probably talking about those 3" wide straps?
jaycocreek wrote:Also fastguns have springs for front, what can't be done with straps.
Torklift has spring loaded barrels that would work with straps..All it would take is someone to make such things like ratchet tie downs for truck campers EV treated..LOL
The point for this thread was would ratchet straps work..Yes they would..
People miss that just an average HD ratchet strap rated for 20K and 5400# working load on both front tie downs is actually 40K in strength and over 10,800# working load..
I hauled lumber on a flatbed behind my Kenworth semi for years and all the truckers use for tieing the lumber down is straps with the ratchet built into the trailer...Never seen one break ever on some monster loads..Straps are an important commodity to truckers especially those hauling lumber..
jaycocreek wrote:
...I think why we haven't seen straps made for truck camper tie downs is the weather factor in the straps degrading to the elements....
