Curly2001 wrote:
I have a 2019 Chevy 2500HD that shows on the yellow sticker on the door, air pressure is 80 psi for the rear and 60 psi for the fronts as max air pressue. Should I tow with these or do I need to inflate the fronts higher?
Thank you,
Curly
The tire pressures on the door sticker aren't "max" pressures - they're the recommended pressures for those tires on that particular vehicle. 80 PSI is the max pressure for an LT load range E tire. This happens to coincide with the recommended inflation pressure on the rear - but not on the front.
As others have said, keep them at what the door sticker says. When I had a single rear wheel truck, I asked my dealer service department if I could/should lower the rear pressures to 65 when not towing. They said to leave them at 80 PSI. From a practical point of view, though, there would be no harm in lowering the rears to 65 when empty... just don't forget to take them back up when loaded or towing.
Rob
