ktosv wrote:
lbrjet wrote:
So it doesn't work by rotation.
Some systems definitely work off of rotation, while others monitor the actual pressure.
OP, if I understand your question correctly, the only way I would think it wouldn't work would be if the two sensors are on the same exact frequency. If your vehicle system is based off of rotation, then it wouldn't be using any frequency and the other system should work perfectly fine.
"on my Ford" was implied. Since the OP had a Ford I was merely explaining that my Ford doesn't work by rotation.
