b_pilot's avatar
b_pilot
Tire pressure on dually
I just bought my first dually. It is a 2013 GMC 3500 HD. The truck I traded was a 2500 GMC HD. I know that to get the max weight on a tire it needs to be aired to the max cold tire pressure. On my 2500 GMC the tire placard showed 65 psi front and 80 psi rear. That is the way I kept the tires aired all the time. The 3500 Dually pressure placard shows 70 psi front and 65 psi for the four tires in the rear. My owners manual doesn't say anything about increasing the rear tire pressure when towing a large load. My question is should I just leave the rears at 65 psi? (All tires are load range E)
I may have just found my own answer. I went out and looked at the max load for each rear tire in the dually configuration. If I increased the pressure to 80 psi, I could load the tires to more than the rear GAWR by 1965 pounds. So, I'm thinking that I should leave the rear pressures at 65 psi.
