rbpru's avatar
rbpru
Feb 29, 2016
Tire pressure on the road.
My F-150 specifies 32 psi cold in the tires. While around town with little or no load in the bed, it makes for a comfortable ride. Towing a TT it feels a bit squishy. Since the "P" tires are stamped 44 lbs. maximium, I have found that 40 psi cold does a nice job.
Leaving Indiana for a trip to Arizona I filled the tires when the air temperature was 19 degrees. The TV tires were filled to 38 psi cold and the 65 psi load range "D" TT tires were filled to 60 psi because I figured to be in warmer temps in a day or so. Sure enough in MO with temps in the 40's at night the tire pressure right on TV 40 and TT 65 psi.
The surprise came when we hit an 80 degree two day warm and sunny spell in OK with temps in the upper 50's at night. I have no idea what the pressure was while driving but in the morning before leaving the TV tires were at 55 psi and the TT tires at 75 psi. I dropped them back to 40 and 65 psi and they have stayed there through the warmer mornings in AZ.
During the day I am not surprised by a 5 to 7 psi change while towing but I was surprised by the in pressure when going from 20 degree mornings to 60 degree mornings.
It should be interesting to see what happens on the way back to Indiana.
The question is; Is this typical for those who tow across contry in weather extremes?
  • Forgot about the altitude, we went from 800 ft to 6000 ft. That might have been part of the change.
    Not likely to switch to LTs, at 40 psi, the Ps do just fine. The DW thinks the TV rides rough enough when not towing already.
  • rbpru wrote:
    Leaving Indiana for a trip to Arizona...
    Did you change altitude? That will affect tire pressure as will ambient air temperature.
  • It is quite normal for air pressure to vary throughout the day. Tire engineers have taken this into account and recommend tire pressure be adjusted only when tires are cold, any other method is flawed.
    We usually check them in the morning before we hit the road and make any adjustments then, we know they will rise in temp but don't fret as they are designed to handle the increase in psi.
  • Adjust tire pressure the first thing in the morning. Then leave them alone until the next morning. That's assuming you are parked for the night. I do "feel" the sidewalls (and bearings) at every rest/fuel stop in an effort to find anything odd.
    I set all tires to max sidewall pressure. Some disagree with that claiming it makes for a rough ride. Never made a difference I could feel. At max pressure all tires are capable of carrying their max load and they experience the least rolling resistance and sidewall flex. That's just me.
  • IMHO you should replace your truck tires with LT tires. After buying my Tundra, I had to buy tires in a hurry because one tire had a bubble on the side wall and we were leaving on a trip (without the trailer). So, all I could get were P rated tires. We weren't doing much camping with our old trailer at the time. Well, after a period of time, we sold the old trailer, bought the new one and started camping in the new trailer. On one trip, I could feel the truck moving a little bit...the way I knew it shouldn't. After thinking about it, I decided to replace the tires with LT tires and the difference was very noticeable. And with the LT tires, you can inflate them to a much higher PSI....I like to inflate the rear tires to 65 PSI when towing. An added bonus was better gas mileage with the LT tires...1-2 mpg depending on conditions.
    Otherwise, inflate your tires to the maximum 44 psi. Air temperature will make a big difference in tire pressure, which is why you have a adjust by the weather season or location.
    I just broke down an bought a TPMS system for my trailer tires and rear tires on the truck. We're on our first trip with the system installed and it's really nice to be able to continually monitor the tire pressures and know that I'll get a warning if the pressure drops, if there is a leak, or if temps go too high. The system wasn't cheap, but less than typical repairs if you have a blowout. And, I can turn on the monitor before hitching up and see if I need to get out the compressor without having to walk around with the tire gauge and check each tire.
  • It's typical Air temperature does effect the pressure of a tire.
    The best thing is to check/set your tire pressure in the morning or after the tires have not been rolling for several hours.
    Don't adjust it as it goes up after traveling or in a warmer climate.
    Just check when cold and you will be good.
