Saskatchewan
May 03, 2018Explorer
Tire Pressure
I saw that one of my tires was low on our single axle Gulfstream Visa TT. I check the sticker on the TT which says it should have ST205/75D 14C tires. It also states cold tire pressure should be 50 psi. I then check the tire to see that it is a Freestar M-108- Radial S/T, ST205/75 R14. It also has on the tire 50 psi. Two questions. I am no tire expert so can someone please tell me if the tire I have on the TT is similar to the one it recommends on the sticker? Second question, even though the tire states its max psi as 50 and that is what the sticker recommends, then I fill it to 50 psi?
Thank you!
Thank you!
