Lynnmor
Jul 10, 2016Explorer
I think that the Stabilitrack is causing the problem. The wheel speed sensors may be not reading correctly and the system is applying the brakes on opposite sides. It needs to be serviced right away. Another test is to use a heat gun (available cheaply at Harbor Freight), and check for higher temperatures on the higher pressured tires. Heat increases pressure.
44,030 PostsLatest Activity: Jan 20, 2025
