Just courious as to the tire wear some of you are getting on the rear of your dually...not mileage so much as wear from each tire, inside vs outside. I noticed the other day that my outside duals are ...
if the roads you drive on have started to rut out the front tires will be in the rut and the inner tires will be in the rut and the outers will be on the high spot, thus more wear
