rooney77 wrote:
Reddog1 wrote:
rooney77 wrote:
I read that some just use the same old stuff from home but I do get hesitant to go with the thicker stuff.
Why, when others post they use the thicker stuff with no problems?
Lack of RV experience. Simple as being a newb. And I'm sure I'm putting too much stock in the manual and not enough on the real world experience of others.
I certainly respect your asking, as I think you should. If only a couple of people used the same paper as at home, I too would be hesitant.
It will hurt peoples feelings on occasion, but I think it is fair to ask someone why they do something a certain way, or why they use a given story. If they don't know why, I question the validity of their input. It does not necessarily mean it is incorrect, but all to often we do things based simply off of peoples beliefs. In the case of the TP, the preference is for the paper to dissolve and not stick to the tank sensors or hang up in the dump valves. A solid piece of paper does not flow as easily through the plumbing.
I use a Macerator when I dump, and so far have had no problems with any TP. My Toilet is directly over the tank, and I can easily see inside my tank. With a mechanics mirror and flashlight, through the toilet, I can see my dump valve.
Wayne
