I have been complicating the same thing here on my OFF-ROAD POPUP of changing out my three 85AH GP24 Interstate Batteries on my trailer tongue area which weigh is around 50LBS each with four each 150AH Trojan T1275 Batteries which weigh around 82LBS each.
I carried four of the 85AH GP24 batteries on the trailer tongue at one time and didn't have any problems using my F150 hitch so I know adding the 200LBS of batteries weight is not an issue for me.
My front 5X8 Deck on my OFF-ROAD POPUP is rated at 800LBS capacity for hauling a ATV unit which I don't do but usually am loaded down with lots of SUPPLIES and camping support items.
I am thinking however it may be a good idea to only install two each of the 82LB Trojan T1275 batteries on the trailer tongue and have the other two each Trojan batteries mounted in the bed of my F150 truck in front of the rear axle just in the front area of the truck bed. I do have two requirements for BATTERY SUPPORT for my Emergency radio Operations for RACES-SKYWARN-NAVY MARS radio setups with just using the truck and for camping off the power grid using the truck and the POPUP trailer. Tieing the two battery banks together when camping will give a good 600AH of capacity. With both units separated I will have 300AHs battery capacity. Today I am doing pretty good with my 255AH Battery capacity but having the extra AHs capacity will be a really good addition for me.
Only using 1/2 of the 48-inch metal tool box on the trailer will allow me to use the remaining room for trailer setup support tools etc...
My OFF-ROAD POPUP layout would look something like this. My drawing only shows 110AH batteries which will be replaced with the 150AH batteries.
Wiring for the truck bed layout would look something like this...
I will be using a 4AWG 2-pin connector/plug arrangement from ETRAILER like this to connect the truck mounted battery bank in parallel with the trailer battery bank...
After I get all of this up and working successfully for me then I want to add at least 360 WATTS of solar panels to the roof of my OFF-ROAD POPUP trail with two that can be relocated to a portable setup POD if needed to assist in re-charging my battery banks during the high SUN daytime charge periods. With my current setup I have to use my 2KW Generator to recharge my batteries each morning when allowed to run my generator which at times has to be split in two different daytime generator run time periods depending on where I am located at the time. It appears I will still have to run my generator each day to do the initial 14.4VDC high current charge and then can switch to the solar panels to attain the 90% or more charge state over the longer period of high sun during each day. My goal of course is always have my batteries at the 90% charge state before I start using them again for the full night run off the batteries until I can charge again the next morning. Otherwise it gets dark on me around 10PM each night hehe... This is all based on to recharge my batteries in a short three period requires at good 15-20AMPS of current per battery or 60AMPS which is not going to be available from my three 120WATT solar panels. The solar panel generally only produce 5-6AMPS DC Current per panel which will work just fine for my setup after I get past the 14.4VDC high current charge period. I should be able to get past the high charge current time with just two hours of running my generator each morning using my on-board PD9260C Converter /charger and allowing the rest of the day running at 13.6VDC charge state using the solar panels. The emphasis being I must be at 90% charge state by 4:30 each day so that if that did not occur I will still have enough time to run my generator for a couple more hours before 8PM at night when I am usually allowed to run my generator.
Just some of my planning here adding more battery capacity taking the added battery weight and other circumstances into consideration...
It does take good planning to be successful each day camping off the power grid.
Roy Ken
