anutami's avatar
anutami
Mar 17, 2018
Torklift Stow n Go fits the Wolf Creek Bumper
I knew there was a better way!!
Single step I have used, requires quite a stretch to get up, and have to grab the ladder to pull myself up. Also, when going out of the camper only have 1 hand free because need to use the ladder as a handle
Glow steps fit perfectly in with pins on the bumper
Close up
Deployed, and now both hands are free don’t need to grab anything
Video clicky
  • anutami wrote:
    Close up
    Mine didn't have that offset bar at the top.
    My step upgrade
    I like the offset style, because you can place it "between" the brackets for the original step.
  • The offset bars are included with the Stow n Go (upgrade kit) bracket because the bracket is wider than standard mount, allows free travel of stairs and not hit tread bolts. As are the 4 pins shown?
    anutami Did you order stairs with stow n go bracket but not use the bracket? Curious why stairs are other wise assembled to use on the Stow n Go.
    yes, I had intentions of screwing the bracket into the bumper but found it is not necessary with my bumper set up. The stairs rest against the top of my receiver hitch, and will just strap them to the hitch when traveling, so no need to remove.
