I have a 2001 S10 that my Dad setup for Flat towing behind his motorhome. Dad passed on and I bought the truck with all the towing attachments.
last Saturday I was flat towing the S10 around with my Curt extension (just like your reese), set at 32" with a set of side angle chains/bars on it. Worked perfect.
32" hitch extension, slides into 2.5" truck receiver
2" receiver plugs into end of 32" extension and drops 6". this may add another 6" of length.
Tow bar plugs into lower connector of this 6" drop
Blue Ox tow bar to S10 (3000 lbs truck)
Original Brake buddy running in S10
Remco drive shaft disconnect on S10 (works perfect after I put a new cable on it and made sure it was a straight run from cab to driveshaft disconnect).
I just need to learn how to unhook the blueox. since nothing where I live is level it seemed to be a PITA to get the pressure off it.
Sunday I loaded the camper late in the day.
This week I need to measure everything to see how much extension I really need to tow the S10. (I can do 24" or 32").
Since I need to run this 6" drop receiver extension that is about 6" long for the tow bar, this extra length may allow me to shorten the extension to 24" and still clear the Fox landing. (I have enough space under truck that I can move back and forth between both lengths without cutting hitch extension.
anyway, hitch weight is very little, only the weight of the 6" drop extension and blue ox tow bar. Not sure but I don't think the towbar puts much side flex it puts on the extension as long as your only going forward.
