- Ron_GratzExplorer
dw1gator wrote:
Your data indicate a load of 100# was transferred to the TT's axles when WD was applied.
Its possible thinking back. But I dont understand what you are seeing. Thers a 20# difference on the front axle and a 60# difference on the rear. Where do you get the 240# ? And that brings up a question. Where should one stand while weighing?
This load is equal to about 13% of the indicated 760# tongue weight.
Based on assumed dimensions of:
TV wheelbase = 116",
ball overhang (longitudinal distance from TV's rear axle to ball) = 58",
and distance from ball to mid-point between TT's axles = 240",
a load transfer of 100# to TT axles would cause approximately:
255# to be added to the steer axle, and
355# to be subtracted from to the drive axle.
For the "WD engaged" weighing, the axle loads should have been approximately:
2900+255 = 3155# on the steer axle, and
3980-355 = 3625# on the drive axle.
The steer axle would have been about 3300-3155 = 145# lighter than when unhitched.
Instead, your data showed:
2880# on the steer axle (suggesting that 3155-2880 = 275# was "lost" from the steer axle), and
3920# on the drive axle (suggesting that 3920-3625 = 295# was "gained" by the drive axle).
On average, the data suggests that about 285#, which was on the steer axle pad during the "WD not engaged" weighing, showed up on the drive axle pad during the "WD engaged" weighing.
(Note: in the previous post, I assumed 240# was moved based on assumed dimensions for a Suburban rather than a Tahoe.)
The driver and all passengers should be in the same seats for all three weighings.
Some drivers use a short pole to press the call button while seated in the TV.
Ron
P.S. I think you're very wise to try to understand how your axle loads change when weight distribution is applied. - billrozExplorerIf I was that concerned about towing I would sell it all and go by taxi , try to enjoy you setup don't let this gargalygoop spoil it
- dw1gatorExplorerThanks lawrosa those videos were very informative.
- dw1gatorExplorer
lawrosa wrote:
Both times the same wt. with gear people etc. Actually if gas is about 8#/gallon, I may have been 60-65# lighter this time compared to first time. Everything else the same.dw1gator wrote:
dw1gator wrote:
ok. I got all the weights. Here goes.
GCVW. 11500. max rating is 13000
GVW 6800. Max rating is 6800
GFAW. 3140. max rating is 3600
GRAW 3660. max rating is 3750
GTW. 5300. max rating for pulling is 7400.
tongue weight is 580. that's 11% of trailer weight.
this is with TV and trailer fully loaded with our gear, passengers, and full tank.
If you look here at my first CAT wts you can see I'm closer on the front axel and less on the rear. Before dual cam install. All other wts are close to same. Except tongue wt.
I dont know if the first #'s were right. Those are actual CAT weights and specs I have listed.
If those are your door tag numbers posted below you are over your rear axle limits..Yes it is. And it was not over prior to dual sway control install.
Im concerned with what you tire side wall says for may pressure and weight ratings. In any rate make sure you put mac PSI cold in those tires
edit.. found it.. Make sure you inflate to max..weight rating of the tires are 2535lbs each
Your only taking 80lbs off the rear with the wd hitch. You can do much better. Its not set up right INO..I agree. I alreadt had Reese WDH with trunion bars. First weights gave me some wt redistribution. I ordered the dual cams and had them installed. Now Im not getting wt distribution.
And there is no way that you were lighter with no WD hitch not installed compared to when you got it installed..No, you misunderstand. I already had WDH for first wts. Only the dual cams were installed prior to these wts.
did you get weighed with full gear , gas, and people? And last time without gear people and fuel? - dw1gatorExplorer
Ron Gratz wrote:
dw1gator wrote:
The numbers don't make sense.
Ok I have more wts and used the calculator that was linked. I also had a Reese dual cam sway control installed and question the correctness. Prior to install I was getting some wt distribution. Now I have same WDH wiith the dual cams but seem to not get any wt distribution
Here are my wts.
With WDH engaged.
Front. 2880
Rear. 3920
Trailer. 4660
Total. 11460
With WDH not engaged
Front. 2900
Rear. 3980
Trailer. 4560
Total. 11440
Truck only
Front. 3300
Rear. 2820
Total. 6120
The data suggest that a weight of approximately 240# somehow got moved from the steer-axle scale pad to the drive-axle pad between the "WDH not engaged" weighing and the "WDH engaged" weighing.
Is it possible that you were standing on the steer-axle pad during the "WDH not engaged" measurement, and were on the drive-axle pad during the "WDH engaged" measurement?
Ron
Its possible thinking back. But I dont understand what you are seeing. Thers a 20# difference on the front axle and a 60# difference on the rear. Where do you get the 240# ? And that brings up a question. Where should one stand while weighing? - Ron_GratzExplorer
Here are my wts.
With WDH engaged.
Front. 2880
Rear. 3920
Trailer. 4660
Total. 11460
Front. 2900
Rear. 3980
Trailer. 4560
Total. 11440
Truck only
Front. 3300
Rear. 2820
Total. 6120
Ron - lawrosaExplorerThis is what that calculator is doing for you. This is the formula...
Weighing #1 -- TT attached and Weight Distribution Activated
Let Front Axle Load be "FA1"
Let Rear Axle Load be "RA1"
Let TT Axles Load be "TT1"
Then, while in same position on scales, take
Weighing #2 -- TT attached and Weight Distribution Not Activated
Let Front Axle Load be "FA2"
Let Rear Axle Load be "RA2"
Let TT Axles Load be "TT2"
Then, drive off scales and drop TT. Return to scales and take
Weighing #3 -- TV only -- TT Not Attached
Let Front Axle Load be "FA3"
Let Rear Axle Load be "RA3"
From the above values, you can calculate:
TV weight = FA3 + RA3
Gross Combined Weight = (FA1 + RA1 + TT1)
- should also be equal to (FA2 + RA2 + TT2) if scale weights are correct
TT Weight = Gross Combined Weight - TV Weight
Tongue Weight = (FA2 + RA2) - (FA3 + RA3)
Load Transferred to TT Axles
when WD System in Activated = TT1 - TT2 - lawrosaExplorer
If you look here at my first CAT wts you can see I'm closer on the front axel and less on the rear. Before dual cam install. All other wts are close to same. Except tongue wt. - dw1gatorExplorerFront. 3600
Rear. 3750
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 03, 2025
