Hanna
Sep 01, 2013Explorer
Tow vehicle question.
I have an 04 Durango limited, it has the hemi and 3.55 gears, and factory tow hitch. Towing max is 7200 lbs. my wife has her heat set on a coachman apex 288BHS. The trailer weighs 4,842 lbs dry and has a gross weight of 7,000lbs. The trailers is 31.2 ft long. The length is my main concern. I will be using the equalizer hitch with 4 point sway control. The question is does anyone think I shouldn't tow this trailer? Will be mostly flat land and maybe 3 hours max travel time.
Coachman 288BHS
Coachman 288BHS
