nagel wrote:
Do others increase / decrease the tire pressure in their tow vehicle when they are pulling the trailer? My truck specs say 35 psi for all 4 tires, but nothing about adjusting when towing.
I'm thinking I want to increase the tire pressure in the rear tires maybe to 40 psi when pulling the trailer. Thoughts? Is their a formula for figuring this out or should I leave it at 35? I'm thinking with the added tongue weight, it could cause the tires to "smash down" a little bit.
You should run the tires at max listed pressure on the side wall, not over.
