raydf's avatar
raydf
Towing capacity for older SUV?
I suspect that questions such as the one I'm about to make have been posted MANY times here but well, please accept my apologies for the repetition if so! The question is the following:
The tow vehicle (a sturdy but older SUV, Mitsubishi Sport 3.0 liter V6) is rated at 5,000 lbs and a 500 lbs hitch weight. The trailer in question has a dry weight of 3,650 per factory specs (Gulf Stream Vista Cruiser 23RSS), a hitch weight of 431 lbs, and a cargo carrying capacity of 2,411 lbs. Adding the cargo capacity to the dry weights gives 6,061 lbs, obviously way over the tow vehicle's limit. However, doing some computations on the size of holding tanks and the expected "stuff" that will be carried in the trailer, I doubt that the cargo will go over 1,000 lbs, for a theoretical weight, loaded, of 4,650 lbs.
My question is: can the noted SUV safely tow this trailer, loaded as indicated?
Thanks!
