โNov-16-2013 06:37 PM
โNov-19-2013 03:37 PM
45Ricochet wrote:
IMO all three will be fine power wise, it's the braking I'd be shopping for OP. 1100 degree rotors just seem to hot for my liking's.
โNov-19-2013 10:24 AM
โNov-19-2013 08:44 AM
โNov-19-2013 08:22 AM
mpierce wrote:
I have a 2014 3500 RAM DRW. Also a 19K toyhauler. The truck handles it great! The EB is fantastic! Most, if not all, reviews say the Cummins/RAM EB is the best one out there. That truck WILL handle the 19K trailer fine. Get 3.73 rears. Unless in big hills all the time, the 4.10 is overkill. 3.42 will have it shifting more. 3.73 good compromise.
โNov-18-2013 06:30 PM
โNov-18-2013 03:29 PM
โNov-18-2013 03:27 PM
โNov-17-2013 04:25 PM
Turtle n Peeps wrote:Terryallan wrote:travelrider73 wrote:Terryallan wrote:
Honestly. You can SAFELY tow right up to the manufacturers posted capacity. They did the research, and math. No need for you to redo it, and lower the capacities the engineers developed.
Well, there's a skeptic in me that wonders how much influence the marketing department has over the engineering department at the Big 3. It seems like they have plenty of reason to push the limits so they can advertise that they have the biggest baddest beast on the road. If everyone pushes a few hundred pounds here and there, all of a sudden there's a tiny asterisk at the bottom of their towing claims... I know, they can't push it too much for fear of a huge lawsuit, but I suspect they push it a little.
In reality. They come down on the very conservative side. Those capacities are not any kind of law. They are the weights that the manufacturer has warranted the truck to carry / tow. In other words. stay in the factory recommendation. And they will pay to fix it, should it break. Go over, and the warranty is void.
So knowing that. They set the weights less than the real capability of the vehicle, to save them having to pay for burnt trannys and things.So knowing that. They set the weights less than the real capability of the vehicle, to save them having to pay for burnt trannys and things.
:h How do they know how big of a trailer you have been towing? :h
โNov-17-2013 04:08 PM
โNov-17-2013 02:51 PM
โNov-17-2013 02:18 PM
โNov-17-2013 01:37 PM
skipnchar wrote:
Interstate highways have the same grade standard in the Rockies as in the rest of the country. 06% is the grade standard to allow relatively easy access to commercial trucking. There are very FEW exceptions where this is exceeded, and then only for a short distance. State highways may be as steep as 08% and be within standards though 6 and 7 are MUCH more common. You would pretty much have to go LOOKING for grades steeper than 8% though they are out there but not on major roads.
Good luck / Skip
โNov-17-2013 10:14 AM
โNov-17-2013 08:38 AM
