Jun-13-2016 09:56 AM
Jun-14-2016 04:23 PM
Jun-14-2016 12:40 PM
Jun-14-2016 09:59 AM
Jun-14-2016 05:26 AM
Jun-13-2016 10:42 PM
need-a-vacation wrote:
Guessing the 1905lbs is a typo, and the 1740lbs Max payload, is that per the yellow sticker in the drivers door jamb?
Jun-13-2016 10:21 PM
Jun-13-2016 06:12 PM
tdp6022 wrote:
My GVWR is 7100lbs the RAWR is 1905lbs and the max payload is 1740lbs.
Jun-13-2016 02:36 PM
Jun-13-2016 01:55 PM
Jun-13-2016 12:33 PM
Jun-13-2016 12:12 PM
Jun-13-2016 11:35 AM
Jun-13-2016 11:16 AM
Jun-13-2016 10:18 AM
APT wrote:
Spend $15 at a CAT scale to get all your weights. Then you''ll know how much you can upgrade. Most half tons exceed some other vehicle rating well below tow ratings. Less than one percent of half tons built can tow 9000 pounds loaded TT with 1200 pounds of TW and not exceed receiver rating, rear axle, and GVWR.
I suspect that 5100 pounds is inaccurate. I bet it's closer to 5800 pounds with 7200 pounds GVWR. Or you can check as equipped payload on the tire and loading sticker, subtract that 700 pound estimate and the rest can be trailer tongue weight.
