โSep-30-2013 01:48 PM
โOct-07-2013 05:46 AM
โOct-06-2013 06:47 PM
Sport45 wrote:wnjj wrote:
You picked one of the speeds where the 4.10 has just changed to next next higher gear. That's where it will have a disadvantage. The problem with your example is there are many more speeds where the 4.10 has the advantage so overall it is more favorable. My chart below will show those areas where the 3.73 is still pulling after the 4.10 shifts.
Will the 4.10 still have certain hill/weight combos where it performs more poorly than the 3.73? Yes, when you are between gears (as in just shifting up) you aren't able to get the engine up to its higher RPM HP.
The difference between available HP and HP demand is what provides acceleration. When you look at the chart from an RPM in each gear point of view, notice how for every point on the RPM range (the slopes are each gear), the 4.10 geared truck has a greater HP advantage because it's there when the HP demand is lower.
The peak of each RPM is 5000 (my choice) and the valleys are ~3000 for the 1-2 shift and ~3350 for the 2-3 shift based upon the 6-speed ratios I used.
Note: I don't expect these actual speeds to match any particular real truck but to simply illustrate the difference. I just used ~35mph for 5k rpm in 1st for the 3.73 truck and 300 ft-lbs flat across 3-5k rpm.
Interesting. So if you're on a hill that requires 250hp to maintain 55mph the 3.73 will let you drop a gear and do it, but the 4.10 gears rev out and limit you to 50mph.
I have 3.73 gears in my F-250 and would have preferred 4.10's. But Ford only allowed 3.73 and 4.30 at the time and I didn't want to go that low.
โOct-06-2013 06:30 AM
โOct-06-2013 06:27 AM
nohurry wrote:
This thread has given me a headache :W
Seriously though, it has been good food for thought. All I really need to know is that the engineers that design these trucks say that if you opt for the lower gear ratio, your tow rating goes up. Not just for that reason, but I'm convinced the gearing gives more capability across all gears. Yes I can just run in 5th gear when cruising down a stretch of level highway and be close to the same, but what about all the other situations? Acceleration, and hill climbing/descending come to mind. If a person has the expendable income, I think it's worth it. If money's an issue, it should work fine as is for 2-3 tows a year.
โOct-05-2013 07:10 PM
โOct-05-2013 03:29 PM
Grit dog wrote:
My 6.2/3.73 is not much of a pulling machine. Honestly doesn't pull any better than my '11 5.0 f150.
I don't think the gear swap will make $2500 worth of difference. You'll still wind it out on every climb just a couple hundred rpms at climbing speed.
โOct-05-2013 02:46 PM
RCMAN46 wrote:
I used my 05 Duramax with the Allison 1000 for my example. The 05 has a peak hp at 3000 rpm and peak torque at 1600 rpm. These would be ideal shift points. Max rpm is 3250 for the 05 Duramax.
I assumed 30 inch tires and a 3.08 rear end for one case and same tires and a 4.10 rear end for the second case. I will accelerate from 40 to 65 mph. A typical speed change when getting on a freeway and sometimes passing a slow truck when hauling my 5th wheel.
With the 3.08 I would be in 3rd gear going 40 mph at 1956 rpm and accelerate to 65 mph where I would be turning 3162 rpm.
Now with the 4.10 I would be in 4th gear going 40 mph at 1837 rpm and accelerate to 65 mph where I would be turning 2935 rpm.
Interesting the 3.08 gives me a change of 1216 rpm and the 4.1 gives me a change of 1148 rpm. Almost the same except the 3.08 is greater and Carecraft claims this will result in a shorter acceleration time.
โOct-05-2013 02:10 PM
Carecraft wrote wrote:
There is a major problem with the Carecraft example. I shift my gears by the rpm the engine is going and not by the vehicle speed.
He assumed in both cases the car was in the same gear. He did not use the transmission for what it is intended.
Here is a neat site to use to calculate rpm's vehicle speeds etc with different transmissions and gear ratios.
http://www.grimmjeeper.com/gears.html
In almost every post in this topic the transmission is not taken into account. Combustion engines have a transmission to keep the engine in its power band if used properly.
In my example my 05 Duramax would perform almost the same with both rear ends with the exception when both are in 1 st gear or both in 5th gear. But if the transmission is allowed to do its job performance in vehicle speeds between 25 and 90 mph will almost be the same.
โOct-05-2013 01:48 PM
Learjet wrote:06Fargo wrote:
:h
4.3 x 400lbs-ft at 3000 rpm at the prop shaft = 1720lbs-ft to the center of the drive wheels...
3.73 x 400lbs-ft at 3000 rpm at the prop shaft = 1492lbs-ft to the center of the drive wheels...
I think the 1720 one pulls harder on a trailer hitch
wrong, you are not going the same mph in your example. IF you are going the same speed then your transmission in the 4.30 is in a higher gear. thus the overall gearing is the same.
Rework your example at 40 mph, then get back to us ๐
โOct-05-2013 01:20 PM
wnjj wrote:
You have to view the gearing change while considering RPM and MPH. That takes into account the amount of HP available and required at each speed.
Carcraft has a nice article that contained this paragraph:Carcraft wrote:
Here's a reason low gears can be beneficial to dragstrip performance that you've probably never considered. Assume that a car is in a 1:1 trans ratio, has 26-inch-tall tires and 3.08:1 axle gears. When accelerating from 50 to 70 mph, engine speed increases by about 800 rpm. Put 4.10:1 gears in the same car, and engine speed increases by 1060 rpm-the difference is 40 rpm per mph with the 3.08s versus 53 rpm per mph for the 4.10s. The greater rate of rpm increase versus road speed provides greater acceleration. Since horsepower increases as engine rpm increases (up to the point when the torque curve drops off at a greater rate than engine rpm increase), the engine is able to overcome loads more easily with lower gears than with higher gears. This helps not only in acceleration but in maintaining road speed under a load such as when climbing a steep grade.
I realize this is about drag racing but pulling hills is about getting the most out of your engine and gearing just like the last sentence suggests.
I actually plotted available HP versus MPH throughout 1st through 3rd gear with both rear axle ratios up to 70mph, shifting each at 5000 rpm. I also plotted an assumed linear increase in demand HP on the same graph. You can see where the lower geared truck HP climbs away from the demand HP more quickly in each gear. I used an estimate of wheel size and assumed a flag torque curve from 3000 to 5000 which is reasonable along with the actual 6-speed ratios. I can try to post a picture if anyone's interested.
โOct-05-2013 09:38 AM
โOct-05-2013 06:18 AM
06Fargo wrote:
:h
โOct-05-2013 05:51 AM
โOct-05-2013 03:44 AM
