noteven
Oct 05, 2013Explorer III
Learjet wrote:06Fargo wrote:
:h
4.3 x 400lbs-ft at 3000 rpm at the prop shaft = 1720lbs-ft to the center of the drive wheels...
3.73 x 400lbs-ft at 3000 rpm at the prop shaft = 1492lbs-ft to the center of the drive wheels...
I think the 1720 one pulls harder on a trailer hitch
wrong, you are not going the same mph in your example. IF you are going the same speed then your transmission in the 4.30 is in a higher gear. thus the overall gearing is the same.
Rework your example at 40 mph, then get back to us ;)
I believe the OP's question around gearing was whether changing to a lower ratio would give better towing performance (acceleration, climbing etc), not what rpm = what mph.
