Big Toe, Thanks. The lack of intercooler would explain some of the lower rated power output of the van 6.0. Also thanks for explanation of the inter/after cooler issue.
Big Toe, Thanks. I really like the new truck (International).
The International looks overloaded, but it is actually way underloaded. It weighs 13,000 lbs less than it's 33,000 GVWR and is using only about half of it's 21,000 lb rear axle weight rating. The rear springs are rated more than the axle, with 23,500 lb main packs, plus overloads, according to the factory build sheet I got with the truck.
The truck was ordered by the Forest Service with the extra heavy rear springs. I don't know why they didn't order it with the 23,000 lb axle too. The 23K axle was available with an air operated locking differential, which was not available in the 21K axle.
The reason the truck sits low in the rear and high in the front is because of the way International builds their 4x4 trucks. They have to use very tall front springs, for the axle and engine oil pan to clear each other. The 4x4's appear to sit about 8" higher in the front than the 2wd's, from what I can tell by comparing with other 2wd 4000 series trucks I run across.
The truck has spacer blocks under the rear springs to lift it up. The rear spring hangers are also mounted lower on the frame than the 2wd trucks, with drop brackets that allow the lower portion of the spring hangers to bolt on below the bottom of the frame rails.
Despite their efforts to increase the rear suspension height, it is not enough to make up the full height difference in the 4x4 versus 2wd front suspension. Possibly that's as far as they could raise the rear, due to driveline angles, or some other issue... I don't know.
I should have taken very accurate before-build and after-build rear height measurements, to know exactly how much the truck squatted. Unfortunately, I didn't do that. However, from all that I can notice from before and after pics and from working on the truck, climbing up and down it 100's of times, relationship between the overloads and their bump stops, etc, it doesn't appear to me the truck sagged more than inch in the rear from what I loaded on it, if it even sagged that much.
I would prefer if the truck did not sit nose-high. It looks stupid. However, I really don't want the rear to sit any higher than it does, even if it can be lifted. It's difficult enough to climb up and down the rear of the bed as it is. Any higher would just make my job harder.
So far as I can see, there is nothing I can do about lowering the front, without risking the axle hitting the engine. So, it is what it is and I accept it...
For size comparison, here is a pic of the other 4x4 F350 parked next to the new truck (I was using the crane to pick the welder off the F350). The F350 has 33" tires and aftermarket heavy rear springs on it.
The spacer block under the rear springs is visible here, as well as the drop brackets for the spring hangers, underneath the frame rail.
Here are seen the upper 2 bolt locations in the frame above the spring hangers at both ends of springs, where the spring hangers would mount on a 2wd model.
