RoyJ wrote:
Me Again wrote:
If you look at the Tesla semi, they have done a lot of aero work to make it slide through the air resistance better. So maybe HD EV pickups will do that also.
It's not the pickup truck itself, it's the modern trailers we haul these days. The tall rear section of a toy hauler is the worst possible shape for Cd.
With semis, they have the luxury of designing the tractor and trailer together. A Euro Mercedes hit 12+ mpg @ 88,000 lbs GVW, that's better than some pickups at less than half the weight.
It would be interesting to put a set of the foldout aero panels you see on the rear of some semi trailers on the back of a tow hauler. I wonder how much that would improve MPG?
I have been down on the companies that gave up rear caps for that reason. Any square corner cause more drag. I went from the 9500 flat back 5th wheel to a 12,400 one with a rear cap and mileage improved.
