spitts55
Mar 26, 2015Explorer
towing
Will a 2011 ford explorer pull my 22 ft travel trailer it has 3.5 cyclone and class 3 tow pkg
Gdetrailer wrote:spitts55 wrote:
IT HAS A CLASS THREE TOW PKG.
Umm.. Doesn't matter.
The "Class Three" towing package includes a CLASS THREE HITCH.
Class three hitch has a MAXIMUM CAPACITY OF 500 lb tongue AND 5,000 lb GROSS TRAILER LOAD, PERIOD.
SEE HERE FOR CLASS INFO
From the website above..
Class 3 (Class III) trailer hitch
Trailer hitch with weight carrying rating of up to 5,000 lbs gross trailer weight and 500 lbs tongue weight. Also sometimes used to refer to a hitch with any 2" receiver, regardless of rating.
From an earlier post that you made you stated "2011 EXPLORER weight carring 2,000 max tongue 500 lbs gcwr 10,096"
So if I read that correctly the "weight carrying" is your "payload"?
If so you need to subtract passenger weights, fuel weight and any other item you place in the vehicle..
The result should be left over cargo weight which could be used for the trailer tongue..
But, at this point in time the trailer hitch just may be your limiting factor..
As someone else pointed out, your vehicle may not have a full on frame.. This becomes a problem because the HITCH is now an integral part of the vehicle frame and can not be removed or changed out..
Changing out the hitch on many newer vehicles is often not feasible due to the hitch becoming part of the crash protection systems..
You are most likely going to need to look for a different trailer, one that has a dry or empty weight at no more than 3,000 lbs in order to be able to have a hitch weight at no more than 500 lbs when loaded..
my 2003 explorer gvwr 5880 max tongue 500 gcwr was 11,600 max towing 7160 lbs
not sure what to do.
