Sep-29-2017 09:06 AM
Sep-29-2017 12:27 PM
bikendan wrote:stevemorris wrote:
yes I thought the payload was low for a "big" truck
From my recent search for a new truck, Tundra payload capacities are second worse, with the Ram 1500 being the worse.
But that Tundra will have no problems with your trailer.
But if you decide to get something bigger in the future, you'll probably have to get a different tow vehicle.
Which is what I had to do.
Sep-29-2017 12:10 PM
Sep-29-2017 11:29 AM
Sep-29-2017 11:16 AM
Sep-29-2017 11:07 AM
RinconVTR wrote:
The Tundra will give you 3/4 ton gas power and torque in a 1/2 ton package.
It holds its value better than any other 1/2 ton for good reasons. Reliability being at the very top.
Downsides:
With 3/4 ton gas power comes 3/4 ton fuel mileage.
Low payload limits larger TT options, to a point. Over 7500lbs actual trailer weight (not dry or gross...but ACTUAL) you're usually bumping the limit of the Tundra's gross vehicle weight rating.
Sep-29-2017 10:27 AM
Sep-29-2017 10:15 AM
Sep-29-2017 09:40 AM
Sep-29-2017 09:37 AM
Sep-29-2017 09:33 AM
stevemorris wrote:
has factory towing package with 7 pin and 4 pin connectors but no brake controller(should be an easy addition) ?
